| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Watts = Volts X Amps. If a 1 ohm resistor is flowing 5 amps of current it's dropping 5 volts across the resistor, and producing 25 Watts of power (heat). The same resistor would drop 20 volts and create 400 Watts with a 20 amp flow. The trick is to figure the maximum current an accessory will draw and size the resistor wattage accordingly. Using a too-small wattage rating will result in resistor overheating and burnout. Higher wattage capacity on a voltage-dropping resistor is always better, as they produce a LOT of heat as they consume voltage. Jerry
