| | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Interested in everyones opinion on the cast iron saginaw four speeds. I have a friend that I will be helping on a AD restore or partial resto mod restore, and he/we are in the planning stages. He would like to keep the stock appearance bias ply tire look retain the torque tube but is interested in the Patrick saginaw 4sp kit. I'm skeptical, years ago, owned a saginaw four speed and was always putting a second gear syncho in it back in the old days power shift one or two times then it ground into second on the third shift. That said, I wonder if that trans can handle the heavier pickup body if driven around responsibly? I know this is a different way seems many go the route of a 5sp open drive line these days, it might come to that but at least want your opinions on this setup. Thanks in advance, Steve 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
