1 members (Hotrod Lincoln),
61
2
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | At normal highway speeds and engine loads, (even heavily loaded commercial engines) there was no measureable improvement with HEI over point ignition, as long as the plugs were relatively new and clean. As the plug gap increased due to wear and/or neglect, the increased voltage capability and the long-term reliability of solid-state coil triggering became a factor. Conventional ignition points simply could not meet the artificially-imposed "50,000 mile service free" mandate in the Clean Air Act, which was the only reason HEI was developed in the first place. Operation of a General Motors HEI system above 5500 RPM required major modifications to the distributor to prevent spark scatter and other problems created by speeds above those the HEI was designed to run. I challenge anyone to show me documented evidence (not opinion) otherwise. Jerry
Entire Thread
Quick question, spark plug gap 283, HEI
| kahoys | 01/14/2018 8:50 PM |
Re: Quick question, spark plug gap 283, HEI
| Justhorsenround | 01/14/2018 9:54 PM |
| Hotrod Lincoln | 01/14/2018 11:26 PM |
| kahoys | 01/15/2018 4:36 AM |
| yar | 01/17/2018 4:00 PM |
| Hotrod Lincoln | 01/18/2018 1:36 AM |
| 59 fleet | 01/18/2018 3:00 AM |
| Hotrod Lincoln | 01/18/2018 3:16 AM |
| 59 fleet | 01/18/2018 3:55 AM |
| yar | 01/18/2018 3:11 PM |
| Maybellene | 01/18/2018 7:16 PM |
| Hotrod Lincoln | 01/18/2018 7:25 PM | |
