9 members (Hotrod Lincoln, delwrench, crenwelge, 2-Ton, Cletus1950, Jay R, Hugh63c10, 1955 1 Series, amtrakjoe),
334
6
Mod | | | Forums66 Topics128,159 Posts1,057,027 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 53 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 53 | Hello all, I bought a 1950 5 window 3100 many years ago. I am working slowly at getting it put back together.
When I bought it the hood would not close as it was forward 1" in front of the front fender edge. I figured that was caused by the front cab mounts rotted out. I have welded in a new cab floor and front motor mounts and now am test fitting hood. It still seems to be 1/2" forward. Also there is a gap between front fender and running board. Could the cab sinking down have an effect on the fender?
Do you guys have pics that could help out? How could I check the shape of the fender? I did get a different hood as well and it seems to be the right size, but alignment is poor.
Thanks, Jerry | | |
