8 members (Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert, Shade Baby),
119
0
Mod | | | Forums66 Topics128,052 Posts1,055,716 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | I don't think there is any downside to it. My 261 will get one this coming spring. Yes, the combustion chamber is of a pretty funky and inefficient design which is just why you might consider it. The single throat carb has to feed that motor from idle to wot so there are some compromises built in. One is that at idle and off idle, it can sometimes run a little fat so the multiple sparks might help get you a cleaner more complete burn. As you said, you only have your time in it.
Mike
