So as we all know, on the Advance Design trucks, radiator stand is the foundation of the front clip. In removing mine, I expected to find the spacer between the bottom of the stand and the top of the front cross member. I did. I was also expecting to find a washer or two. I didn't, but that's not a big deal. I did, however find the anti-rattle "gasket/grommet" between the bottom of the stand and the top of the two-hole spacer. It appears to be a reinforced rubberized canvas or something -- and not quite the same material as the fender welting, either. Are replacements for this available? If not, what would be a suitable replacement?
~ John
1949 Chevrolet 3804 In the Legacy Gallery | In the Gallery Forum 1973 IH 1310 Dump 1963 Kaiser M38A1 2001 International/AmTran RE3000 "Skoolie" 2014 Ford E-350 4x4 (Quigley)
