| | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | "LP" is actually a mixture of Propane and Butane. Butane has more BTU's than the Propane, but it also "freezes" (stays liquid) at 32 degrees F. The Propane vaporizes at something like -70 degrees F. so more of it is mixed into the gas blend in the winter when it's needed for getting the vaporization process started. Once the engine begins to run and the coolant warms up, the heat exchanger can start vaporizing the Butane to take advantage of the extra power available by turning it into a gas that can be mixed with air for the right power output. Jerry
