| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Air bags will take more work to install but will make for a much nicer ride than air shocks.
The axle on a '50 1/2 ton already sits above the springs.
I'm using a set of 3 1/2" spacer blocks from Sid Drappel on the back of my '53. That's an easy mod that still allows you to haul a load. | | |
