1 members (MikeE),
70
2
Mod | | | Forums66 Topics128,031 Posts1,055,436 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Does anyone know of someone offering an entire LS3 plastic long block? P-Ayr offers a partial one but with no bell housing bolt hole and no exhaust manifold bolt holes. We do our swaps with the vehicle on the drive on lift where both above and below areas can be observed for clearance/interference problems and mount patterns can be made in a comfortable standing up position. If lift is raised for cherry picker leg clearance it is then too high to swing engine/trans assembly in plus I hate cherry picker legs being in the way. With our plastic sbc and Windsor sbf plastic engines one can just set them in by hand. Have only used one 350 in the last two or three years so the LS is the one to have facilities for. Thank you.
Evan
