| | | Forums66 Topics128,132 Posts1,056,385 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,074 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,074 | Not surprising that they don't match up. The critical thing would be the position where the body mount bolts go.I believe the Factory Assembly Manual has dimensional information for the floor of the body. I know it has locations of bolt holes, etc on a side view. Check the FAM for those critical dimensions.
For the angle of the tabs on the end of the body mount channel, it's likely going to be "beat to fit - paint to match". That's going to be my task come next spring when I pull the body off to repair the rusted out floor.
