9 members (frogfarmer, J Lucas, Gdads51, carbking, Charles in CA, Wally / Montana, Nick in Manitou, sron48, 1 invisible),
88
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I was thinking about this today, and although grinding down the "burr" may let more oil out of the shaft it may still not get up to the vent hole. If you add the height of the "burr" plus shaft wear, the top of the shaft will be that far from the top of the rocker shaft bore. There is likely to be quite a gap for any oil to jump. Most of the oil will likely leak out the sides of the rockers before reaching the vent hole.
See the USA in your vintage Chevrolet! My Blog | | |
