With intermittent issues like what you have can best be solved by driving it until it gets worse.
I have had an issue with a '53 235 with a loud hydraulic lifter until the engine reaches operating temperature. Finally it is now clacking even after fully warmed up. I can now pull the valve cover and find out exactly which lifter is making the noise and replace it.
Carl
