2 members (Gdads51, 1 invisible),
118
8
Mod | | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Yours is a very interesting problem. I spent most of my career in instrumention of some sort and don’t remember ever seeing it. The gauge needle is going full tilt to both pegs and very quickly at that. This makes me think that you might have a ‘dirty’ supply voltage if the truck was running. I would troubleshoot the problem by first disconnecting the sender wire at the gauge. With key on, if the problem goes away you know where to start looking. If it stays, I would remove the (+) side wire and use a battery charger clipped to the (+) side of gauge and negative side of charger to gauge housing. If problem is gone then it’s in your voltage supply wire or gauge ground. If it stays then your in the market for a new gauge. Good luck
