8 members (Bisbee, 49Chief, DadsFirstPickup, D B Cooper, joe apple, Otto Skorzeny, cmayna, 1 invisible),
77
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | welcome to the site! The master cyl diameter on my 58 Viking 60 was 1 1/4. Napa had the kit. You will want to rebuild all of the wheel cylinders as well and replace all the brake lines, both rubber and steel. They may look OK on the outside but rot and rust from the inside. Napa shows both the 1 1/4 and 1 1/2 kit for a 59. The 1 1/2" cylinder kit as a UP209. Raybestos part # is MK209 and is 10$ cheaper at Rock Auto than Napa.
Both places should have wheel cylinder kits. There are 2 different styles for the rear so, you need to pull them apart to see which ones you have. | | |
