you should be able to hear and feel it. especially if you shift it wrong, you'll hear it grind before it gets into gear!
Really, once you shift it a few times, you'll get it. (think of shifting your trans without using the clutch, same basic idea as but it shifts much faster than you would shift the trans).
Mike
