0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Cold, lean engines backfire. You probably didn't use enough choke. I like to use full choke and crank an engine until it fires without touching the gas pedal, then release the choke about halfway to keep it from flooding and stalling. Using a little choke for a couple of minutes during warmup is usually needed, depending on the outside air temperature. Jerry
