That's a stomp switch for a 12V starter, which is a good thing. The small terminal should have a wire connected to the coil + terminal which bypasses the ballast resistor during starting to provide full battery voltage to the coil. After the engine starts the resistor will drop the voltage at the coil to around 9V to keep from burning the points.
