| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | A pretty close estimate can be done without pulling the pan. Mount a dial indicator on the lower part of the bellhousing with the stem on the flywheel, and pry the harmonic balancer forward and the flywheel back. The movement of the dial needle will be the end play of the thrust faces. Jerry
