| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | For looks. The old springs center bolt fits in an off set hole in a block while the open rear spring saddle is centered under the axle tube which throws the rear way forward. With the front of the tire partially hidden and a huge gap behind the rear it looks funky. Some use a long saddle and drill another center bolt hole about 1.5" in front of the existing hole. Some custom U-bolts are then needed. If you have a hydrastatic drill press with infinite speeds you can drill a new center bolt hole through the entire spring pack. Even a plain old HSS drill will go through a spring if the speed is exactly right. We bring the drill down against the spring at zero speed and then with mild pressure and cutting/cooling fluid slowly raise speed till curlings start to come off the drill flutes.
Evan
