| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | Thanks! I believe it's possible to adapt a less expensive, more available vacuum chamber to the stovebolt advance bracket with a small piece of angle iron and a couple of sheet metal screws or pop rivets. GM used the same advance unit on virtually all their V8's for many years, so that would be a good candidate. Jerry
