I put a 327 in my '51 1 ton panel with a T5 behind it. The T5 bolted right up to the bell housing. The shifter actually came through the floor in the same place as the old Saginaw did. You'll just have to reconfigure the "pivot" for the clutch linkage. Good luck.
ED
