2 members (Buckeye998, TUTS 59),
338
6
Mod | | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,870 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,870 | Good grief- - - - -just pull the grease seal, and the inner bearing simply lifts out. There's no need to remove the outer race unless it's damaged. Clean, inspect and reassemble the bearings (both of them) with a new seal, and drive on! The type of ball bearing used in older Chevy front hubs is perfectly capable of handling side loads- - - -it's designed that way. It's amazing how much misinformation gets passed off as gospel truth, with nobody challenging it! Jerry
