The wheel cylinder has a female. The hose has a male and female. The male end of hose goes into the wheel cylinder. The female end of hose is attached to frame and receives the male flare nut on the brake line/tubing.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
