7 members (Gray_Ghost, 52Carl, Gdads51, Peggy M, papas52, Otto Skorzeny, baldeagle),
144
2
Mod | | | Forums66 Topics128,165 Posts1,056,999 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | They're standard Grade 5 1/4-20 bolts- - - - -8 ft/lbs. (96 in/lbs) or so should be plenty. A drop of blue Loctite on the threads would be a good idea. I'd install the gasket dry, although the later V8 pumps don't use a gasket at all. Jerry
