Listen to I. B Hoggin, mount your doors then work on the pillar / outer cowl for marking your door gap. I didn't and now am paying the price of cutting it all back apart.
Just make sure if you are doing the entire floor at once that you brace everything to keep the cab from tweaking.
Good Luck!
