| | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | Too much and/or poorly mixed hardner will also result in paint bleed thru from the peroxide (main ingredient of hardner) especially the lighter color coats. Poor mixing can also result in pinholes. To make the filler set up faster just raise the ambient air temperature and if the panel you're filling is cold pre-heat to 75-80 degrees F. with a hair dryer or heat lamp.
34 & 35 trucks are the greatest
