| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 112 | This weekend I crawled under the truck and inspected whole driveline... it looks like the rear transmission mounts have been modified/changed... the rear mounts that attach the bellhousing to the cross-member are not bolted down and a newer cross-member was installed behind the transmission that bolts to the rear of the transmission... it doesn't look like a hack job as all the pieces look finished... looks like a kit was installed and not home made
anyone have an idea of what kit was installed .. or why? all the correct pieces (engine/trans/torque tube) in the correct location... dont understand the reason for modified mounts
Id try and post picture but don't have very good luck in past
Old Truck addict 1950 chevy 1 ton napco 1956 gmc 1 ton dually napco 1954 chevy 3/4 ton napco 1957 gmc civil defense napco panel
