0 members (),
119
2
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | I was driving the other day and honked the horn and it did shut off. Had to drive home with it blaring. I took the horn off and checked the connections in the steering wheel. Everything looked correct. The contact spring was working properly and connections are clean. The only way for it to stop is to disconnect the horn. Could I have a problem with the relay switch? Not sure how to proceed. I'm work with a 64 k10. Thanks John
1964 K10 Fleetside Pickup Truck | | |
