| | | Forums66 Topics128,157 Posts1,056,872 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Nope, no coil spring Carl. I first thought the steering wheel was touching the mast causing the issue. I took the wheel off and can rotate the shaft and get the problem of the shaft hanging up a bit on the bearing a bit.
Dennis
40 Chevy 1/2 ton
