2 members (rick46ia, NJC),
112
3
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,944 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,944 | First thing to do- - - - -with any type of battery, is to remove both battery cables and thoroughly clean the battery posts and the inside of the cable clamps with a wire brush. Reinstall the cables and tighten them. DO NOT TELL ME THE FOLLOWING:
"I shook the cables and they're tight".
"Everything looks good."
"It can't be that simple."
"It's gotta be the - - - - - - - -" (Fill in the blank with the appropriate item you suspect.)
At least 95% of the "no crank- - - - -everything goes dead" complaints can be fixed by a simple cable clamp and post cleaning- - - - - -at least it's been that way for the 60 or so years I've been tinkering with automotive electricity! Jerry
