7 members (BCBill, Gdads51, Lightholder's Dad, joe apple, Hawkman, greenie-reddy, TUTS 59),
190
0
Mod | | | Forums66 Topics128,101 Posts1,056,176 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | I'm not impressed by the idea of putting a suspension system for a subcompact car under a truck- - - - -even if it's going to become a Cowboy Cadillac that never carries a load in the bed. At least give it suspension designed to carry the weight of a V8, like a mid-1970's Chevy Nova, or a Camaro subframe, etc. You also get the benefit of a properly-engineered suspension and steering system that's actually designed to handle in a turn, not something that just keeps the frame off the ground at a car show and might let you drive in straight lines and stay in your own lane. It costs a lot less to clip the frame off about the front of the cab and fit a complete frame assembly, instead of doing a butcher job on the original frame, figuring out how to mount a rack & pinion steering gear to minimize bump steer, and design some Rube Goldberg U-joint system to connect it to the steering column! Jerry
