| | | Forums66 Topics128,035 Posts1,055,556 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | On an internally balanced engine it is OK to make a new key way 180 degrees from the factory one in both the dampner and crank snout. Can't do this on an externally balanced engine like a 400sbc or a 454. The fit should be close, 0.0005 to 0.001 so the balancer can't "waller" during acceleration/deceleration. We have an ancient key way machine that can actually do this with the engine assembled but by the time the front clip is pulled and the machine set up a Bridgeport would probably save money. Machine is now used by a friend to put new key way for drive pulleys/sprockets on ditching machines. When one of these machines is down price is not discussed to get it back in action. X2 on replacement.
Evan
