| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Unless the balancer is keyed to the crankshaft in some way, the tension of the fan belt and the load of driving the charging system and the water pump will eventually unscrew a center bolt. Jerry
