1 members (Hotrod Lincoln),
73
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 36 | Hello all I am a novice when it comes to Chev trucks and would like to expand my knowledge.
I have a 160 inch wheel base Chev truck which was used by the Australian Army and has Holden build plates on it. I am thinking this is a 2 ton truck. The manual I have says that this should have 5 stud front wheels and 10 stud rear wheels. My truck has 10 stud front wheels. That is if I am counting the studs correctly. I am counting the inner studs as I am under the belief the outer studs hold the rim together. I am guessing this was an Army requirement to keep the wheels common.
I also have a ½ ton chassis. I’m wanting to put the cab on the shorter chassis as it will be a more practical size for want I want. I will be keeping the original I beam as the trucks guards/fenders appear to be wider than the smaller pickups. I’m wanting to run steel wheels as opposed to the split rims. Is there a drum brake option that will match up to the big truck bearings and stub axles that will have a stud pattern to go with 5 or 6 stud 16 inch steel wheels. Thanks for any advice.
Steve
