3 members (Southerntruck, 2-Ton, 1 invisible),
78
3
Mod | | | Forums66 Topics128,142 Posts1,056,491 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | The problem with the normal Cardan-type U joint is its tendency to lock up at certain points in its rotation due to changes in angular velocity if it's flexed too far from a straight-line situation. Using a double-Cardan joint with two crosses with a center link between them solves the angular velocity problem, but it requires a pillow block support to be installed on both sides of the joint for stability purposes. That's not difficult to do assuming there's enough space available. The double-D collapsible shaft is always a good idea! Jerry
