0 members (),
88
3
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I can describe a little of the AD setup that has the vent window. The main glass rides in a channel both front and back. The back channel is semi flexible and the front channel is mounted on the vent divider. The window mechanism has one arm with one roller on it. It rides inside the channel rail that is mounted to the bottom of the glass. | | |
