| | | Forums66 Topics128,287 Posts1,058,544 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Update...
Step 1 - tightened up the rear shoes. No difference.
Step 2 - bled the master cylinder, minor improvement.
Step 3- bled the fittings on the proportioning valve, no change.
Step 4 - got a pretty good vacuum bleeding kit and bled everything twice again with that, no change
Step 5 - adjusted the pushrod on the pedal/master. That seemed to help a tiny bit.
I have a slight pedal now, and it gets better if I pump it 10 times but it bleeds off when I release and push it again.
Continuing to diagnose...
1953 GMC 1-Ton Pickup with 350 and 700R4
Entire Thread
New brake install, pedal goes to floor
| Chad M | 06/10/2017 7:12 PM |
Re: New brake install, pedal goes to floor
| showkey | 06/10/2017 7:27 PM |
| 3B | 06/10/2017 7:59 PM |
| yar | 06/11/2017 1:08 AM |
| Chad M | 06/11/2017 1:59 AM |
| Norcal Dave | 06/11/2017 2:11 AM |
| Chad M | 06/14/2017 3:47 AM |
| Wrenchbender Ret. | 06/14/2017 8:59 PM |
| thoroco | 06/14/2017 11:43 PM |
| Chad M | 06/15/2017 1:26 AM |
| thoroco | 06/15/2017 3:01 AM |
| Chad M | 06/17/2017 7:50 AM |
| showkey | 06/17/2017 1:25 PM |
| Chad M | 06/17/2017 2:26 PM |
| thoroco | 06/17/2017 4:58 PM | |
