3 members (Ponchogl, carbking, 1 invisible),
66
2
Mod | | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Just remove the timing gear, not the whole cam. The myth that a timing gear can't be changed with the cam in the engine was invented by people who never made a living working on these engines. Drill and tap the gear hub if necessary, use a puller to remove the old gear, and heat the new (aluminum) gear a little to allow it to be tapped on without enough force to damage anything. Remove the fuel pump and use a pry bar to hold the cam forward against the thrust plate while installing the new gear. Back when I ran a shop, I'd fire anybody who couldn't put a new timing gear on a stovebolt engine before lunchtime! Jerry
