| | | Forums66 Topics128,287 Posts1,058,544 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Chad M, if the master cylinder is mounted below the level of the disc brake calipers, then 2 p.s.i. residual pressure valves are recommended to prevent backflow to the master cylinder from the calipers. That being said I don't believe that is causing your lack of pedal. I don't mean to insult you, but in trying to think where air could be trapped the only thing I could think of is could the calipers be upside down with the bleed screws facing down rather than up? I would be tempted to remove the brake lines from the master cylinder and plug the ports to make sure the master cylinder is not bypassing. Did you bench bleed the master cylinder? | | | |
Entire Thread
New brake install, pedal goes to floor
| Chad M | 06/10/2017 7:12 PM |
Re: New brake install, pedal goes to floor
| showkey | 06/10/2017 7:27 PM |
| 3B | 06/10/2017 7:59 PM |
| yar | 06/11/2017 1:08 AM |
| Chad M | 06/11/2017 1:59 AM |
| Norcal Dave | 06/11/2017 2:11 AM |
| Chad M | 06/14/2017 3:47 AM |
| Wrenchbender Ret. | 06/14/2017 8:59 PM |
| thoroco | 06/14/2017 11:43 PM |
| Chad M | 06/15/2017 1:26 AM |
| thoroco | 06/15/2017 3:01 AM |
| Chad M | 06/17/2017 7:50 AM |
| showkey | 06/17/2017 1:25 PM |
| Chad M | 06/17/2017 2:26 PM |
| thoroco | 06/17/2017 4:58 PM | |
