I've seen it done before, worked and looked really good. Go for it.
If you are using remote control for the doors than that can also be your exit. And have a lever on the latch on the inside to activate it manually and also a waterproof switch hidden somewhere to use in case of lock out. On my 50 I also put a cable hidden under the truck as a fail safe way to pop the door if all else failed.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
