| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | check the thread on knocking after a new vacuum advance.
Static time using the pointer on the bell housing and the BB in the flywheel. #1 cylinder on compression stroke. The light should just come on. I use a home made T-handle crank to turn the engine over.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
