| | | Forums66 Topics128,094 Posts1,056,483 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | http://67-72chevytrucks.com/vboard/showthread.php?t=7387551) Will I need to unbolt every rod, remove timing gear cover and remove the crank to remove/replace the upper crank rope seal or can I just remove the main caps and slightly lift the crank to remove/replace/seat?
