High temp rattle can paint is self priming, but you do want to wire brush the rust off and bake out any oil before you coat it.
The only spot on a stovebolt engine that actually needs high temperature paint is the exhaust manifold, the rest of it stays cool enough that standard paint is fine.
Paint & Body Shop moderator
