| | | Forums66 Topics128,129 Posts1,056,361 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | A little more detail about what you're doing would be good. The extra battery is either a good idea, or totally unnecessary and useless, depending on what you're doing with it. If whatever accessory you're planning to power is only going to be used when the engine is running, you don't need another battery. If you're worried about running the starting battery down when the engine is off, you MUST install an isolation solenoid. Jerry
