3 members (DaveV, Phak1, TUTS 59),
223
2
Mod | | | Forums66 Topics128,162 Posts1,056,942 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Use a 3/8" diameter vacuum hose to the booster, and install a vacuum reservoir if possible. I like to make the reservoir from a piece of 3" PVC plastic pipe about 18" long with caps glued onto both ends. It will fit nicely inside the frame rail under the cab, and if you paint it black it almost disappears. Use a T fitting threaded into one end cap and a one-way check valve between the reservoir and the intake manifold to prevent vacuum loss on a long uphill grade, etc. This also works to prevent vacuum wipers from slowing down or stopping when vacuum is low. Jerry
