| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Screw two 3/8-16 bolts into the harmonic balancer, into the puller attaching holes and use a pry bar between them. A better way is to use the chisel-shaped end of a shepherd's crook wrecking bar between the flywheel ring gear teeth and the edge of the bellhousing. Jerry
