7 members (fonz8261, Otto Skorzeny, physcult, Bill Hanlon, Phak1, moparguy, Joe H),
77
2
Mod | | | Forums66 Topics128,128 Posts1,056,682 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | What contact do you have it wired to? It should connect to the high beam terminal on your dimmer switch. If you accidentally connected it to the feed line that feeds power to the dimmer from the light switch it'll do what you describe. It should connect to which ever of the side lugs you have going to your high beams, shown in the image below. Do not connect it to the center lug. <CLICK>
