7 members (1955 1 Series, Lightholder's Dad, 55shaker, DuckRancher, Jon G, TexasA&M48Truck, 1 invisible),
70
3
Mod | | | Forums66 Topics128,200 Posts1,057,405 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,186 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,186 | What he ^ said. The way they'd go about it is to either change the yoke on the driveshaft to match the rear axle or possibly use a u-joint that's one size on one part of the cross and another size on the other part to match up. You'll likely be messing with the driveshaft anyway, so welding on a new matching yoke isn't that big a deal.
Messing with the yoke on the rear axle potentially introduces issues with bearing preload or pinion seal.
