I admire your courage to replace that whole system- every single item on my 3/4 ton brake system was toast (including the drums), and that contributed to my decision to swap out the rear axle and change to modern brakes all around...those 3/4 ton brake parts aren't cheap! Jim Carter has the wheel cylinders, at
Oldchevytrucks.com
~ Dave
1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission
