| | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I know that the drive shaft needs to be shortened 3 inches. I don't want to cut my original drive shaft. My truck is a 59 1/2 ton all original drive train. I procured another drive shaft and now find that the universal joints are not the same size. The caps are different sizes as well as the width across the joint. I seem to remember 40 yrs. ago you could buy a conversion u joint that would have different size caps, but I don't remember if the width across the caps were different. Any ideas from those who have done this already? How did you do this.
Thanks
Tommy 59 apache 1/2t 261 short stepside | | |
